saturn L Series RS problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46030
Printed Date: May 16, 2026 at 12:52 AM
Topic: saturn L Series RS problem
Posted By: adidas4501
Subject: saturn L Series RS problem
Date Posted: December 26, 2004 at 2:31 AM
i recently installed a remote start in a Saturn L-Series and i'm having a problem getting the security light to turn off.
i powered all of the ignition and acc wires properly and had to isolate the key in cylinder wire with a relay to get the check engine light off.  i used a data bus security bypass that seems to work fine (ie. the car starts without the key)
thanks everyone
Joshua
Posted By: NowYaKnow
Date Posted: December 26, 2004 at 7:45 AM
What bypass did you use? Sounds like the problem I would recommend a manual tuning bypass for these cars.
Mike
Date Posted: December 26, 2004 at 12:04 PM
i used a universal gm bypass for transponder and passlock (IB-GMBP)
i'll give it a try... my friend just gave me a 2 relay diagram for a passlock II bypass.  i should have it in a week if anyone needs it
thanks,
Joshua
