multiple batteries
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47654
Printed Date: May 15, 2026 at 11:56 PM
Topic: multiple batteries
Posted By: 86753090-9
Subject: multiple batteries
Date Posted: January 13, 2005 at 7:35 PM
I HAVE A 92 PLYMOUTH DUSTER WITH A 90 AMP ALTERNTOR ,200 AMP RELAY ISOLATOR, 5 BATTERIES IN THE REAR IN PARALLEL WITH 0 GA.PWR AND GRND COMING FROM THE ENGINE (GROUND TO THE FRAME AT THE ENGINE ,PWR FROM THE ISOLATOR TOO THE REAR BATTERIES, 8,000 WTS. TOO THE SUBS,AND  1,000 TO THE DOORS.
1)IS THIS A GOOD WAY TO WIRE THE SYSTEM?
2)DO I STILL NEED TOO GROUND EACH OF THE REAR BATTERIES?
3)HOW CAN I FIGURE WHAT SIZE FUSES TO RUN AFTER THE ALTERNATOR AND TOO EACH BAT?
4)I THINK I AM PULLING 750 AMPS,DO I NEED A 750 AMP ALERNATOR,OR 2) 375 AMP ALTERNATORS?
Posted By: godd dan it
Date Posted: January 13, 2005 at 8:51 PM
I cant really answer any of your questions. But why do you need 5 batteries? It doesnt give you any extra power. All it does is when the car is turned off.......you can play your system or other electronics for a longer period of time. Upgrade your alternator to a higher output....that is the way to go.
Posted By: forbidden
Date Posted: January 13, 2005 at 10:12 PM
No doubt, put that car into Jenny Craig, get a HO alternator, lose the caps lock and post the rest of the system by brand and model# please.
