98 honda radio and cig lighter dead
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49134
Printed Date: May 08, 2026 at 4:13 AM
Topic: 98 honda radio and cig lighter dead
Posted By: caltwo
Subject: 98 honda radio and cig lighter dead
Date Posted: February 01, 2005 at 5:57 PM
need help to source out my problem. the car radio(not a factory installed honda radio,but a honda radio none the less-replacement for stolen original)and the cigarette lighter(mobile phone charger )no longer work. Both operate on the same 20 amp fuse, which is fine-not burnt out. i have been told there is no relay controlling this circuit. can anyone help me source out this problem-p.s. no factory code on radio as it is a replacement. thanks
caltwo
Posted By: auex
Date Posted: February 01, 2005 at 6:43 PM
Have you tested every fuse, including those under the hood?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Velocity Motors
Date Posted: February 01, 2005 at 7:01 PM
As in past recommendations for fuse testing, make sure you use a DMM to test for burned fuses.
Posted By: shnackelberry
Date Posted: February 08, 2005 at 2:16 AM
the fuse you need to replace is under the hood
