saturn l200 2002
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49402
Printed Date: May 07, 2026 at 8:19 PM
Topic: saturn l200 2002
Posted By: stiverp
Subject: saturn l200 2002
Date Posted: February 05, 2005 at 11:52 AM
Where is the ign module. I've looked all over the drivers side engine. I'm looking for the PURPLE / white tach wire. Where is it, what does it look like, or is there a better way?  thanks, Stiver
Posted By: stiverp
Date Posted: February 05, 2005 at 11:55 AM
Also the plug behind the instrument cluster is easily gotten to, why is there not a wire there to pick up tach signal from.  Stiver
Posted By: KarTuneMan
Date Posted: February 05, 2005 at 12:05 PM
V-6  ?? or 4cyl.
Astrochart shows 2 possable tach wires...both at the same location. WHITE or LT.BLUE @ the PCM connector on the back side of the engine near the firewall, and next to the brake booster. Its a small "box" with 2 sets of plugs.
Get the wire from the plug that opens toward the drivers fender.....youll see what I mean, they open on opposite sides
Posted By: SPIKECD40
Date Posted: February 17, 2005 at 10:07 PM
did u try to get the tach at any of the fuel injector wires, it should still be PURPLE / white
Date Posted: February 17, 2005 at 10:08 PM
did u try to get the tach at any of the fuel injectors, it should still be PURPLE / white
Date Posted: February 17, 2005 at 10:09 PM
you can get it at any of the fuel injectors also, it will be PURPLE / white
