01 Ford Taurus
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53240
Printed Date: May 15, 2026 at 5:39 PM
Topic: 01 Ford Taurus
Posted By: ford18
Subject: 01 Ford Taurus
Date Posted: April 04, 2005 at 5:46 PM
i had a simple question.. I have an 01 Ford Taurus with the 3.0 vulcan engine.. and i was gonna run an amp power wire through the fire wall to power a 4 channel amp for my speakers and i already have an aftermarket pioneer deck in there.. i just needed to know of any safe spots to drill or if there is a grommet i am missing.. cause there is the brake booster and the abs stuff and the power steering rack that i dont wannna tag when i am drilling.. so has anyone done an 01 taurus before?
Rbv
Posted By: geepherder
Date Posted: April 04, 2005 at 8:04 PM
On vehicles that give me a hard time, I just cut a slit in the boot where the steering shaft enters.
Posted By: stevdart
Date Posted: April 05, 2005 at 12:09 AM
Yeah, I drilled my 01 Taurus just directly under the brake pedal linkage from the inside.  Pushed a coat hanger through until I saw it from the engine side.
Posted By: ford18
Date Posted: April 05, 2005 at 11:02 PM
how did you drill and not tag your brake booster?
Rbv
Posted By: slow_hoe2001
Date Posted: April 10, 2005 at 7:04 PM
no need to drill dude. i have a 01 taurus ses and i just pulled down the fender well plastic crap on the driver side and there is a boot for what you want in there. just b cautious of the spring when u run your wire. i tied mine up w/ zip cord and drilled it to the body. hope this helps
