Mitsubshi 2002 Wire Harness
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5603
Printed Date: May 07, 2026 at 12:55 PM
Topic: Mitsubshi 2002 Wire Harness
Posted By: angelique2006
Subject: Mitsubshi 2002 Wire Harness
Date Posted: November 18, 2002 at 1:53 PM
Hi,
Could you please give me the wire harness color scheme for a 2002 Mitsubshi Montero Limited SUV?
Thank you
Angelique
If you are not the lead dog, your the view never changes.
Posted By: DeathsJester12V
Date Posted: November 18, 2002 at 5:00 PM
Which Harness Angelique.......the ignition or the Radio??
Đễẳ†ђş 12\/ Ĵęśŧē®™
Posted By: djfearny2
Date Posted: November 18, 2002 at 5:49 PM
what harness as death said and your quote is stupid or worded  bad.
Jon
Installer/Help Technician
---coral springs florida---
Date Posted: November 19, 2002 at 9:15 AM
Thank you DeathJester12V for your response.  I wish to know the color scheme for the ignition.
Posted By: Velocity Motors
Date Posted: November 19, 2002 at 9:25 AM
This is for the Montereo:
|              12V|blue/white          |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|blue/black          |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue / YELLOW         |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ red       |-  |ETACS ECU *4                |
|     POWER UNLOCK|BROWN / white         |-  |ETACS ECU *4                |
|       LOCK MOTOR|blue/black          |   |fuse box                    |
|     UNLOCK MOTOR|blue/red            |   |fuse box                    |
|    DISARM DEFEAT|blue/red            |   |fuse box                    |
| PARKING LIGHTS +|GREEN / WHITE         |   |driver kick panel           |
|       HEADLIGHTS|yellow              |-  |headlight switch            |
|     DOOR TRIGGER|RED / green           |-  |ETACS ECU *4                |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|         HOOD PIN|blue/black          |-  |ETACS ECU *4                |
|  FCTRY ALARM ARM|blue *1             |-  |driver door harness         |
|FCTRY ALRM DISARM|brown *1            |-  |driver door harness         |
|       TACHOMETER|yellow              |   |inspection connector *2     |
|      SPEED SENSE|WHITE/ blue          |   |data link connector *3      |
|       BRAKE WIRE|blue/orange         |+  |brake pedal switch          |
|     HORN TRIGGER|lt GREEN/ black      |-  |steering column             |
|           WIPERS|blu/red (L), blue(H)|+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |driver window switch        |
|  RF WINDOW UP/DN|RED / wht - grn/wht   |A  |driver kick panel           |
|  LR WINDOW UP/DN|red - green         |A  |driver kick panel           |
|  RR WINDOW UP/DN|RED / yel - grn/yel   |A  |driver kick panel           |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|RED / black           |+  |radio                       |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|blue                |+  |radio                       |
| RADIO ILLUMINATE|GREEN / WHITE         |+  |radio                       |
|    POWER ANTENNA|pink                |   |radio                       |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.   *1 These wires will also lock and unlock the doors. Unlock requires a double pulse.  *2 The inspection connector is on the driver side of the engine compartment behind the relay box.  *3 The data link connector is under the driver side dash to the right of the steering column.  *4 The ETACS (Electronic Timer Alarm Control System) ECU is under the driver side dash, attached to the fuse box.
Date Posted: November 19, 2002 at 9:27 AM
This is for the Montero SPORT
|              12V|white               |+  |ignition harness            |
|          STARTER|blk/yel or blk/blu  |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
| SECOND ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|BLACK/ red *1        |-  |right rear side of fuse box |
|     POWER UNLOCK|BLACK/ blue *1       |-  |right rear side of fuse box |
| PARKING LIGHTS +|GREEN / WHITE         |   |headlight switch            |
|       HEADLIGHTS|red                 |-  |headlight switch            |
|     DOOR TRIGGER|GREEN/ red           |-  |top of fuse box *2          |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|                    |   |                            |
|  FCTRY ALARM ARM|blue / YELLOW         |-  |drivers kick panel          |
|FCTRY ALRM DISARM|BLACK/ red           |-  |drivers kick panel          |
|       TACHOMETER|wht/blk or white    |   |coil or ignition module *3  |
|      SPEED SENSE|yellow/white        |   |data link connector *4      |
|       BRAKE WIRE|green               |+  |brake switch                |
|     HORN TRIGGER|green               |+  |horn or relay underhood     |
|           WIPERS|blu/red(L),blu/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|red - green         |A  |drivers door switch         |
|  RF WINDOW UP/DN|RED / blu - blk/yel   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers switch or kick panel|
| SUN RF OPN/CLOSE|blu/wht - blue      |A  |motor at front of sunroof   |
| RADIO ILLUMINATE|GREEN/ blue          |+  |radio                       |
|    POWER ANTENNA|WHITE/ black         |+  |radio                       |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.   *1 Warning! When doing door locks on these trucks make sure you DO NOT cycle the door locks rapidly. This may cause the ETACS module to fail and the door locks will no longer work. Also, you MUST add diode's to the lock and unlock output from our units to prevent damage to the ETACS. Make sure you insert the diode's with the cathode (stripe side) towards our unit.  *2 In a 2 pin plug.  Also found in the drivers 'A' pillar.  *3 On the 2.4L, tach is wht/blk at the coil on the left front of the engine compartment. On the 3.0L and 3.5L it is white at the ignition module next to the coils on the right rear side of the engine compartment under the plastic motor cover.  *4 The data link connector is under the driver side dash, near the relay box.
Date Posted: November 19, 2002 at 11:29 AM
Ok I need to start gettin up earlier...everyone beats me to the wiring code posts....LOL
Đễẳ†ђş 12\/ Ĵęśŧē®™
Date Posted: November 19, 2002 at 11:56 AM
Quit drinking so much you boozehound posted_imageposted_image
Date Posted: November 19, 2002 at 11:58 AM
Hey Velocity...I've jsut been handing the beer out!!!  I don't drink all of it....plus...I was sober last night...outta beer..........I was up late for other reasonsposted_imageposted_image
Đễẳ†ђş 12\/ Ĵęśŧē®™
Date Posted: November 19, 2002 at 12:07 PM
posted_image
