2002 Toyota Tacoma Double Cab Alarm Wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=612
Printed Date: March 28, 2026 at 5:57 PM
Topic: 2002 Toyota Tacoma Double Cab Alarm Wiring?
Posted By: suntzumd
Subject: 2002 Toyota Tacoma Double Cab Alarm Wiring?
Date Posted: May 05, 2002 at 6:54 PM
Does anyone have a wiring diagram for a 2002 Toyota Tacoma Double Cab (4Door).  I need it to install an alarm.  Any help would be greatly appreciated.
Posted By: Velocity Motors
Date Posted: May 05, 2002 at 9:22 PM
Toyota
Tacoma
1996-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT IGNITER ON PASSENGER WHEELWELL *
Parking Lights:
GREEN (+)
16 PIN GRAY CONN. AT FUSE BLOCK **
Headlights:
RED / BLUE (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
IN SCHEAMTICS
OEM Alarm  Arm:
N/A
NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * BLACK Tach Wire Also Located In 26 Pin Connector Behind Glove Box.
Toyota
Tacoma
1996-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED & WHITE
Starter  Kill:
BLACK
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
BLACK/ WHITE (-)
2 PIN GRAY CONN. AT FUSE BLOCK **
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
RED / WHITE
12 PIN CONN. IN DRIVER'S KICK ***
Power  Unlock:
RED / YELLOW
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
** Fuse Block Located In Driver Kick Panel. *** Child Safety Locks: RED / BLUE (-) In Same Connector As Door Lock Wires Above.
Posted By: jellyman
Date Posted: June 06, 2002 at 10:05 AM
suntzumd, Did you complete the install?  I am about to embark on the same project on a Double Cab. Any Tips?
