2000 montero sport factory alarm disarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6138
Printed Date: April 01, 2026 at 12:23 AM
Topic: 2000 montero sport factory alarm disarm
Posted By: laoreflxzn
Subject: 2000 montero sport factory alarm disarm
Date Posted: December 02, 2002 at 12:11 PM
Can someone help me figure out where to locate the disarm wire for the factory alarm?  Trying to remote start but the factory alarm kicks in and stops it.  Also need to know where to locate the door lock and unlock.  Thanks
Posted By: Velocity Motors
Date Posted: December 02, 2002 at 12:18 PM
  • |POWER LOCK|BLACK/ red *1        |-  |right rear side of fuse box |
    |POWER UNLOCK|BLACK/ blue *1       |-  |right rear side of fuse box |
  • |FCTRY ALRM DISARM|BLACK/ red           |-  |drivers kick panel          |
*1 Warning! When doing door locks on these trucks make sure you DO NOT cycle the door locks rapidly. This may cause the ETACS module to fail and the door locks will no longer work. Also, you MUST add diode's to the lock and unlock output from our units to prevent damage to the ETACS. Make sure you insert the diode's with the cathode (stripe side) towards our unit.
Posted By: securinu
Date Posted: December 02, 2002 at 6:11 PM
i have some dfferent color for the disarm not sure if sport and limited are different but this profile says it is sport colors. i think jeff uses dei wire program i use wiremagic. hopefully one of them will work for you
lock=BLACK/ red
unlock=BLACK/ blue
disarm=blue yellow
all 3 are ( - ) and in the driver kick or @ alarm connector behind left dash speaker by the knee
although i have never seen a montero with an alarm i believe they are dealer installed the plug is behind the left dash speaker by the knees. also like jeff said make sure you use diodes or relays the etacs module is very sensitive.
