Source for small 12V normaly closed relay
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62091
Printed Date: May 15, 2026 at 11:02 AM
Topic: Source for small 12V normaly closed relay
Posted By: audioduck
Subject: Source for small 12V normaly closed relay
Date Posted: August 26, 2005 at 2:40 PM
I'm experimenting with some LED lighting on my motorcycle.  I'm looking for a small in size normally closed 12V relay.  The reason I'm looking for a normally closed realy is that I'd like to have the LED function as a running light but then alternate with  the turn signals when they're activiated.  (i.e.  It goes off when the turn signal blinks.)
The LEDs I plan to power are only 0.018 amps so current capacity isn't really an issue.  I'd like somthing small enough to fit in a small space but not so small that it's hard for a fat-fingered guy like me to solder/connect it. Any body know of a product/source?
Posted By: jstruckman
Date Posted: August 26, 2005 at 4:31 PM
Any 5 post relay can either be normally closed or open.
Jazzy
Posted By: sneakycyber
Date Posted: September 13, 2005 at 9:50 PM
Radio shack carries a small circut mountable 12 volt dc spdt relay that should meet your needs. I picked up  a few for wiring some switches but I never got around to using them.. let me know if they work.
Posted By: diabloscope
Date Posted: September 24, 2005 at 5:22 AM
Damn if you break open an old alarm brain you will find some kool small ones in there  ,They work great, use them all the time
