1997 Honda Accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6538
Printed Date: March 30, 2026 at 1:45 PM
Topic: 1997 Honda Accord
Posted By: demeanor
Subject: 1997 Honda Accord
Date Posted: December 11, 2002 at 2:28 PM
Is there any place or any one who could direct me in the right direction...?  I'm having a bit of a difficult time trying to find out the wiring schematics (for a Honda Accord 2 door coupe ex) for the security system that comes stock with the car.  their system has a starter cut off circuit, and if i disconnect the module, the car don't start.  i just need the wiring info to be able to splice into that wire so that the car would start when the alarm gets disarmed.   if i just make a new wire to the starter, the security system goes off when alarm arms/disarms.
thanks in advanced, your help is appreciated.
It's better to ask a "STUPID" question...than to know a "STUPID" answer. :-)
Posted By: 10nesne1
Date Posted: December 11, 2002 at 9:35 PM
The factory alarm plug is located above the fuse box and the factory starter relay socket is located above and behind the fusebox.  It looks like an old Alpine Starter kill relay.  If you are installing an alarm and have an old alpine relay than just unplug it and plug in the relay.  The Starter wire is BLACK/ White.  You will have test all the wire from the factory alarm plug.  Door trigger is BLACK/ white, Trunk trigger is Blue/black.  Power lock is Black.white and Power unlock is Orange.  All those wires are on the factory alarm molex.
Have Fun.
