amp mounting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6815
Printed Date: May 16, 2026 at 1:30 PM
Topic: amp mounting
Posted By: gary9303
Subject: amp mounting
Date Posted: December 17, 2002 at 5:27 PM
hey guys, got a question, i have a 1997 chevy blazer and Im gonna put some music in it. would be ok if i mounted the amps and such under the rear seat or would that make a need for a a fan
Posted By: webguy
Date Posted: December 17, 2002 at 5:34 PM
As long as you can see airspace around the amp and it doesn't interfere with the mechanics of the seat slide, go for it. Just be careful not to run your wiring too close to the seat bolts and don't use the seat bolt for the amp ground.
Clean tools = Clean work!
Posted By: gary9303
Date Posted: December 17, 2002 at 7:01 PM
why not use the seat bolt for a ground?
Posted By: webguy
Date Posted: December 17, 2002 at 7:21 PM
Read this post. That will pretty much explain the do's and the do nots......
https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=2&TopicID=6711
