96 hyundai accent won’t start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73028
Printed Date: May 14, 2026 at 5:08 AM
Topic: 96 hyundai accent won’t start
Posted By: infinitiqx4
Subject: 96 hyundai accent won’t start
Date Posted: February 17, 2006 at 5:46 PM
so I was driving my hyundai up a hill and it overheated causing it to stall.  I thought nothing of it until I was unable to start it back at home.  I tried to research if it has a fuel cutoff switch during overheating or what but to no avail.  I have good cranking and spark, but no fuel.  I think maybe my crank position sensor.  I'll check it later.  Any other suggestions as to what to check for?  Thanks.
Posted By: geepherder
Date Posted: February 19, 2006 at 7:06 PM
It's a 10 year old car- check the fuel pump.  Make sure the fuel pump relay is getting good power, and that it's good.  Try to fill up religiously when it gets down to a 1/4 tank and you'll likely never have another fuel pump problem again.
