DOOR RELAYS, 93 DODGE INTREPID==ASAP
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7305
Printed Date: May 14, 2026 at 6:30 AM
Topic: DOOR RELAYS, 93 DODGE INTREPID==ASAP
Posted By: austinreed21
Subject: DOOR RELAYS, 93 DODGE INTREPID==ASAP
Date Posted: December 28, 2002 at 8:55 PM
hey, i havea  VIPER 500 ESP alarm, and have that all installed, but cannot get teh keyless entry feature to work, --- HOW DO I WIRE IT UP? i know i will have to get relays, 30A, 12V right? standard ones, and i also have a wiring diagram already- how do i wire up the relays to lock/unlock the doors?
p.s.     if possible could somebody include a schematic of the relay, showing for each post what wire is attached, thanks a ton! posted_image
-austin reed-
Posted By: Velocity Motors
Date Posted: December 28, 2002 at 10:21 PM
  • Door Lock ][ORANGE / White --------------- BLUE wire on the H2 plug
  • Door Unlock ][Pink/Purple --------------- GREEN wire on the H2 plug
  • Try this and if it works properly you will not need relays. Relays are only needed if the alarm does not have alternating polarity lock wires.
    Date Posted: December 28, 2002 at 10:24 PM
    i need a relay, can you give me that info too please?
    -austin reed-
    Date Posted: December 28, 2002 at 10:42 PM
    https://www.velocitymotorsport.com/install_notes/Converting_Outputs.jpg
    Use the NEGATIVE INPUT ---------------->POSITIVE OUTPUT diagram and make sure that you use the (-) trigger wire on the H2 plug to engage the relays with this diagram.
    You can use the (+) trigger to postive output from the previous post as well, doesn't matter.
