290i-c command start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7315
Printed Date: May 14, 2026 at 6:20 AM
Topic: 290i-c command start
Posted By: majorj13
Subject: 290i-c command start
Date Posted: December 29, 2002 at 12:27 AM
I just got a new 290i-c command start, I was wondering if anyone would have the wiring guide and step by step wiring instructions, also a wiring guide for a 1992 olds cutlass cierra. Thanks in advance
Posted By: majorj13
Date Posted: December 29, 2002 at 11:20 AM
My main concern is what wires do I hook the 30amp fuse to??
Posted By: Velocity Motors
Date Posted: December 29, 2002 at 11:36 AM
If it's like any other CS model, you hook up the fuses to the RED and the RED / BLACK wires.
Posted By: majorj13
Date Posted: December 29, 2002 at 12:00 PM
This is my fisrt install on a CS model, I have done 3 or 4 Auto Commands, I got this Cs 290i-c for christmas and am trying to put it in wifes car but I need install instructions for the cs290i-c and a wiring guide for a 92 old cutlas ciera
Any help would be greatly appreciated thanks
wade
Posted By: majorj13
Date Posted: December 29, 2002 at 5:36 PM
where does a guy hook the tach wire to????
Date Posted: December 29, 2002 at 9:06 PM
Here is a CS diagram for another model, but CS has had the same wiring harness for the past 6-8 years: Command Start CS310i.
Wiring information for the Olds:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |drivers kick                |
|     POWER UNLOCK|black               |+  |drivers kick                |
| PARKING LIGHTS +|brown               |   |light switch                |
|       HEADLIGHTS|yellow              |+  |light switch                |
|     DOOR TRIGGER|white               |-  |underdash lt, ctsy lt       |
|  TRUNK/HATCH PIN|gray                |-  |at light (wagon only)       |
|TRNK/HTCH RELEASE|black               |+  |release switch              |
|       TACHOMETER|PURPLE / white        |   |distributor/coil pack*1     |
|       BRAKE WIRE|white               |+  |brake switch                |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |wiper switch                |
|  LF WINDOW UP/DN|dk.blu - brn        |A  |in drivers door             |
|  RF WINDOW UP/DN|dk.blu/wht - tan    |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|dk. grn - pur       |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|lt. grn - pur/wht   |A  |in drivers door or dkp      |
Notes:
*1 Some coil packs rear of engine above transaxle.
Posted By: majorj13
Date Posted: December 29, 2002 at 11:11 PM
great thanks, I got every thing hooked up, Now when I push the remote to start the car it starts but starter keeps cranking, why is this???
Thanks again
Date Posted: December 30, 2002 at 8:41 AM
You do not have the tach wire properly programmed. When CS makes the units it is set for 6 cylinder mode. You will need to program it for 4 cylinder mode.
Posted By: majorj13
Date Posted: December 30, 2002 at 9:21 AM
I left it a factory settings, and the car is a 6cyl, I hooked tach wire to the white wire on the coil pack
Date Posted: December 30, 2002 at 9:25 AM
Is there a PURPLE / WHITE wire in the same plug that you can tap into ?
Posted By: majorj13
Date Posted: December 30, 2002 at 12:39 PM
OK I got the PURPLE / white wire and tapped into it, Now when I start the car with the remote it turnsover starts then shuts off, anymore idas for me thanks again
Date Posted: December 30, 2002 at 1:22 PM
The only other one is an injector. Use the uncommon colored one, but then you must program the CD to a 1 cylinder ingine with a medium idle speed.
Posted By: majorj13
Date Posted: December 30, 2002 at 1:36 PM
OK, I have programmed it for 1 cyl and tried all three settings for 1a.1b.1c 2cy; & 3 cyl. It seems to start better on 1b this is what happens though, It starts and runs for about 2 seconds and then shuts off. I am baffled what else could it be?
Posted By: majorj13
Date Posted: December 30, 2002 at 9:45 PM
Whooah, got her working thanks for the help had to use wht wire on coil pack and reset CS and program for 6cyl
Date Posted: December 30, 2002 at 10:43 PM
Awesome !!
Posted By: Jet1t
Date Posted: January 26, 2003 at 1:38 PM
It looks like I may have almost the same problem. I bought this 270i without the wiring diagram or book and with the help of this site and its members I have it all hooked up. I'm installing it into an 89 Voyager MiniVan when prssing the trunk button it flashes the lights 10 times. The door lock and un\lock work properly . Pressing the start allows the starter to start the vehicle for approx. 1 second then shuts off. With the tach wire installed to the blk/grey at the coil it does this . If I disconnect the tach wire it starts and stays running for 5 seconds with the starter spinning then shuts off. Is there a reset procedure for command start starters that may help ?
Thanks In Advance
Date Posted: January 26, 2003 at 6:24 PM
You have the wrong tach wire. It should be a gray or gray/black .
Posted By: Jet1t
Date Posted: January 26, 2003 at 7:52 PM
Yes sorry my typo error it is connected to the grey coil wire.
Jet
Jet
Date Posted: January 27, 2003 at 8:05 AM
Is this a 6 cylinder or a 4 cylinder engine ?
Posted By: Jet1t
Date Posted: January 27, 2003 at 10:12 AM
Its a 3.0 V6 .
Jet
Date Posted: January 27, 2003 at 10:16 AM
Have you reset the tach learning on the unit for a 6 cylinder ?
Posted By: Jet1t
Date Posted: January 27, 2003 at 10:30 AM
No not sure how to reset anything on this CS unit I have no documentation for it. Is it possible to hook up tachless I have installed a few others like that and they seemed to work fine. If not any help would be greatly appreciated.
Jet
Date Posted: January 27, 2003 at 10:53 AM
The CS does not have a tachless mode.Click the link below for a programming sheet for the CS270i ( which is the same as the 290i )
Command Start Programming Instructions
Posted By: Jet1t
Date Posted: January 27, 2003 at 11:19 AM
That should help out a ton  Thank You , I'll give it a try and let you know.
Thanks Again
Jet
Posted By: PLAYER69
Date Posted: January 27, 2003 at 11:24 AM
Just so you know the 290 is a bit different then the 270 in that it has a different transmitter.  Button 1 is the on on the left, button 2 is the right and button 3 is the same as holding both buttons down at the same time.
Posted By: Jet1t
Date Posted: January 27, 2003 at 11:44 AM
Yes my transmitter is exactly like the one in the scan. The model I have is the 270i so the quick guide you gave me is right on the money thanks !
Jet
Posted By: Jet1t
Date Posted: January 28, 2003 at 1:37 AM
I've tried to reset the unit with the hood pin method and the lights come on for 3 seconds and go off when you open the hood. After pressing the switch down and releasing it the lights flash once but they do not stay on. Is there something I may be missing. I've rechecked all the connections , not sure where to go from here.
Jet
Posted By: PLAYER69
Date Posted: January 28, 2003 at 10:20 AM
Open the hood.
Wait for lights to go out.
Press hood switch and realease.  Park lights will come on.
Press hood switch AGAIN while lights are on and release.  They should stay on at this point.
Posted By: Jet1t
Date Posted: January 31, 2003 at 11:49 PM
O.k. not sure how to explain this but I do have it working now. Is it possible that the unit I have doesn't have 9 steps for programming channel 1. Each time I reset the unit and tried to program it there would be only 8 flashes in the total sequence. The vehicle never stayed running and after resetting the unit without programming it the starter would not respond to any button pushes. I reset and programmed it leaving out step 1 and it started and has been working ever since. It still flashes 10 times when I press the trunk button not sure what this would be either. If anyone may have any insight on this it would be appreciated. Thanks again Jeff and Player69 for all your help.
Jet
Posted By: PLAYER69
Date Posted: February 01, 2003 at 12:05 AM
I don't think that is the proper programming for the 290.  There is 1 to many steps i think.  The remote arming shouldn't be there.
It is supposed to flash 10 times when you push the trunk button.
