getting 12v from a 24v system?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74134
Printed Date: May 13, 2026 at 3:09 AM
Topic: getting 12v from a 24v system?
Posted By: 4187
Subject: getting 12v from a 24v system?
Date Posted: March 08, 2006 at 11:53 AM
I have customer with a 1986 military issued humvee with the 24v system.  Does anybody have any ideas on how to get a 12v switched ignition out of this?
Posted By: mad550
Date Posted: March 08, 2006 at 2:23 PM
A reducer and 24v relays don,t go from one battery as when charging you'll spike the alarm with 18-19v
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
Posted By: xscash
Date Posted: March 08, 2006 at 10:42 PM
not only that....when drawing from 1 batt. the vehicle will not see the draw from that batt and increase the charging on the system....this will result in a dead batt situation.  i found this to be in every case a radio was mis wire in any costuction equipment.
Posted By: 4187
Date Posted: March 09, 2006 at 10:43 AM
where can I pick up a 24v relay?
Posted By: KPierson
Date Posted: March 09, 2006 at 12:02 PM
You can pick up a 7812 from Radio shack if your output needed is less then 1A.
Kevin Pierson
Posted By: xscash
Date Posted: March 09, 2006 at 6:42 PM
look in jc whittney...they always have some retarded part that everyone will need some day....24vdc-12vdc converter
Posted By: datspeed77
Date Posted: March 29, 2006 at 2:25 PM
Or you pick up a 7812 to run the trigger for a 30amp relay!  Haven't worked on any 24V systems yet.  Looks like it'll be fun.
