reset with a wrench?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75411
Printed Date: May 13, 2026 at 10:27 AM
Topic: reset with a wrench?
Posted By: Ravendarat
Subject: reset with a wrench?
Date Posted: March 30, 2006 at 9:26 PM
I had an installer show me a trick at another store and found it interesting and kinda worrisum as well. He said that if you trip  a check engine light, pull the negative off the battery and hold a wrench to the negative lead and rub the other end of the wrench on the positive post of the battery. He showed me this on a cav and it worked fine but I am still kinda worried about doing this with some of the new vehicles out there. I understand that its discharging any residuals in the vehicle but on some of these new vehicles with can-bus and what not is this gonna mess up their on board systems?
Posted By: firstrax
Date Posted: March 31, 2006 at 7:51 AM
I dont think you want to mess with that.
Theres plenty of inexpensive tools out there to do the job right. Besides, any reset will not remove the reason the check engine light came on in the first place.
Posted By: auex
Date Posted: March 31, 2006 at 9:01 AM
Yeah, all he was doing was discharging any caps. The same thing is done by leaving it unhooked for 15 minutes, and this is much safer.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
