Humming Sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=79411
Printed Date: May 14, 2026 at 6:10 PM
Topic: Humming Sub
Posted By: dchris_
Subject: Humming Sub
Date Posted: June 21, 2006 at 1:46 PM
ok, This is wierd,
I drive a 98 plymouth noen, 5 speed, I noticed the other day, that there was a humming coming from my sub. I don't know where it came from, because i'v had the car for a couple of months now, and i havn't notived it till the other day.
I pulled the e-brake, and it stopped..
so the humming stops when the e-brake is on, and starts when it is off.
It's a single output 800W Kenwood Amp, And a 1200W Kenwood Sub.
Also , when i slow down and turn a corner it get's louder ( not the humming ) but the sub.
I don't know what would make something like this happen other then power problems for something.
I have a capassitor, but it's not wired in. Would this end the problem?
Your Info and Help would be greatly appricated !!!!!
Here I Am.
Posted By: sparkie
Date Posted: June 21, 2006 at 8:13 PM
Check your power and ground connection to the amp. Check them at all points from start to termination at the amp. You may have a bad connection somewhere. You can also check to see if both RCA cables are OK and not pinched anywhere.
sparky
Posted By: dchris_
Date Posted: June 25, 2006 at 12:04 PM
Ok, well I got half the problem fixed.
I checked all the wires, nothing seems to be wrong with them, But the humming is still there with the e-brake off. Of course it starts again when the e-brake is on. so i'm lost as to what it could be.
If anyone else has an idea I would love to hear it.
Here I Am.
