How does box wall affect port tuning?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80733
Printed Date: May 14, 2026 at 5:19 PM
Topic: How does box wall affect port tuning?
Posted By: testtones
Subject: How does box wall affect port tuning?
Date Posted: July 25, 2006 at 10:49 AM
If I use a wall of the box as one of my port walls how does it change the tuning / length of the port when designing an enclosure and is there a way to adjust for this on winsid?
Posted By: stevdart
Date Posted: July 26, 2006 at 9:30 PM
Keep the basics in mind when you do the build:  end of the port must have space.  Leave 3 or 4 inches minimum.  The port opening on the outside of the box has to have this space, too, but that's a no-brainer because nobody would wedge their port opening against the car.  If the port is built as slotted ports usually are, with one of the port walls shared as a box wall, calculate the port structure width as equal to the width of the port plus the width of the extra wall.  As said above, the entire port structure has to be calculated as displacement.  The rest of the airspace is what WinISD is using when it gives you volume.
