honda motor swap
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=80942
Printed Date: May 14, 2026 at 5:19 PM
Topic: honda motor swap
Posted By: wolfman12
Subject: honda motor swap
Date Posted: July 29, 2006 at 5:43 PM
Can anyone tell me if I can install an 88 integra 2.0l duel over head cam motor into a 91 civic.The integra is an automatic but the civic is a 5 speed stick.Will it bolt up to a standard.Any help would be great thanks.
Posted By: KarTuneMan
Date Posted: July 29, 2006 at 5:45 PM
https://www.hondacivicforum.com/default.asp Jump on here and try that question. You'll get more answers
Posted By: civicdetailer
Date Posted: July 29, 2006 at 6:56 PM
if the integra is a b-series and the civic is a b series then the trannies should work together. however if the civic is stock motor its a d- series and d-series and b-series motor and trannies are not compatible
------------- Nitrous is like a hot girl with an STD. You know you want to hit it, but you are scared of the consequences.
Date Posted: July 29, 2006 at 7:33 PM
i have an 88 acura intgrars what class is my motor better jet what is my motor
Date Posted: July 30, 2006 at 6:13 AM
honestly im not sure about the older integras. there should be a stamp on teh front of the engine block on the left side that says "b20" or b16" or "d16y7" or something like that.
