limiting current to charge batteries
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86413
Printed Date: May 14, 2026 at 1:04 PM
Topic: limiting current to charge batteries
Posted By: jasondavis05
Subject: limiting current to charge batteries
Date Posted: November 29, 2006 at 7:31 PM
Use a resistor.
Check this out to know what to use.
https://www.satcure-focus.com/tutor/page2.htm
Posted By: master5
Date Posted: November 29, 2006 at 11:29 PM
forgive me if I am wrong but everything I have ever been taught about electronics would lead me to believe current would not be an issue here...well at least because you have plenty more available then you need.
Basically as long as the VOLTAGE of the power pack is rated for 3v..I can't see a problem, in other words at 3v what would cause the battery to draw more current then it needs or is able to?
A resistor could be used if you needed to drop the voltage..but the resistors power rating would need to be taken into account..
The basic rules of electricity..
Current is the rate of flow...votlage is the "push" or "force" of the flow...resistance is any opposition to the flow..and power is the product of current and resistance.
If I am wrong here someone please post because this is what I have come to understand.
Posted By: master5
Date Posted: November 29, 2006 at 11:31 PM
oops, I meant power is the product of current and voltage....P = IE...slip up...lol
Date Posted: November 30, 2006 at 4:09 AM
I don't think your wrong at all; infact I think you are right on the money about "current would not be an issue here" but he asked so.....
With Ohms law we can calculate what resistor is needed to get a specific current. If we have a constant voltage over the resistor in this case 3V, we just need to work out supply voltage / needed current = resistor value
3v / .350A = 8.5714
So we need a resistor of 8.57 ohm but if you don't find one with this value you have to change it. To solve that problem always take a value that's higher and you can find what the current will be. Say you use a 8.6 ohm resistor you would have 3v / 8.6 ohm = .348A or 348ma and to find the wattage for the resistor just V*C=W or 3V * .348A = 1.044W and again you might want to use a resistor with a higher power rating.
Ok I think thats it, I hope there aren't any typeO's it's late.
Posted By: master5
Date Posted: November 30, 2006 at 8:54 PM
Agreed but I still see no point to it. Just remember to place the resistor in parallel if you wish to limit current. By putting a resistor in series you will drop the voltage considerably...You will put the resistor in parallel to control current, although in this case I don't see a logical reason why.
More basic rules..the current stays the SAME in a series circuit..after all it has no where to go or (branch off) but the voltage drop at each load adds to equal the total voltage.
The current branches (divides) in a parallel circuit..but the voltage stays the same.
