unusual situation, dump truck tarp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92335
Printed Date: May 14, 2026 at 1:11 AM
Topic: unusual situation, dump truck tarp
Posted By: smalloy
Subject: unusual situation, dump truck tarp
Date Posted: March 31, 2007 at 2:06 PM
I am a dumptruck driver. Most trucks have an electric motor that rolls/unrolls the tarp,like a convertable top on a car. I found a 12V gearmotor to retrofit my truck from a hand crank. What i need to know is 2 things, what is an easy / inexpensive way  to make the motor forward and reverse, and how do i tell the motor to stop at the end of it's stroke and turn off? I'll be happy to provide more details if needed
Thanks,
Shaun
Posted By: KarTuneMan
Date Posted: March 31, 2007 at 11:41 PM
You might want to contact hotwaterwizard.
https://www.the12volt.com/installbay/members.asp?SF=Hotwaterwizard&Submit=Search
Posted By: smalloy
Date Posted: April 01, 2007 at 8:38 AM
 Thanks KarTuneMan..
Posted By: hotwaterwizard
Date Posted: April 01, 2007 at 1:33 PM
For a Tarp on a Big Dump Truck, you need a Big motor.
Usually something like a Wench Motor.
I deal with Electric Hose Reels that have a Wench Type Motor with a Chain drive.
These are expensive Motors.
With a hose reel they pull the hose out manually and just push a button and hold it in until the hose is all rolled up then you release the button.
This involves a push switch and a relay. You could simplify this with a push switch for starting a car. These are Heavy duty enough to operate the motor without a relay.
I will see if I can find pictures for you when I have more time.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Posted By: smalloy
Date Posted: April 01, 2007 at 2:02 PM
 Thanks, 1 of our other trucks has a motorized tarp rack. if you flip the switch 1 way the tarp unrolls, flip the switch the other way, it rolls up. but without tearing the whole thing apart... i can't figure out how it works
Date Posted: April 01, 2007 at 2:29 PM
You could buy it already made.
https://www.harpstarps.com/electricwindupsystems.php
Stockton California
Posted By: linixmotor1968
Date Posted: April 19, 2007 at 11:59 PM
we can offer the 12 VDC worm gear motor for truck's electric tarping systems. The gear ratios are avaialble in 60: 1 and 90:1.
LINIX MOTOR CO., LTD. HENGDIAN GROUP
Skype: jin.jinyue
Tel: 0086-579-6622113(10 lines),
Fax: 0086-579-6630757
E-mail: 168@linix.com.cn
MSN: linixmotor1968@hotmail.com
www.linix.com.cn
