oxygen sensors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94285
Printed Date: April 30, 2026 at 6:16 PM
Topic: oxygen sensors
Posted By: semperfiguy98
Subject: oxygen sensors
Date Posted: May 27, 2007 at 3:50 PM
Trying to figure something out here.  My car has a check engine light "Catalyst inefficiency".  I was wondering if there is an inexpensive way to create an O2 sensor simulator using radio shack parts.  Here's what I know so far.  The upstream sensors should show between 0.1 and 0.9 volts depending on A/F ratio.  The downstream sensors should show around 0.45 volts fluctuating slightly between .4 and .5 volts.  How can I create something that produces an artificial signal to my ECM showing ~.45 volts?  Any help would be appreciated.
Posted By: ringojam
Date Posted: May 27, 2007 at 7:43 PM
They sell them on e bay 02 simulators.
Jamaica home of the worlds fastest man.
Date Posted: May 27, 2007 at 10:05 PM
Quote-
Semperfiguy98  -  "I was wondering if there is an inexpensive way to create an O2 sensor simulator using radio shack parts."
It's not as much fun buying something as it is creating it...
Posted By: KPierson
Date Posted: May 27, 2007 at 11:14 PM
I beleve they send a pulse signal.  The longer the pulse the higher the voltage.  You can simulate them with a 555  timer and a few parts.
Here's a link I found through google:
https://www.mkiv.com/techarticles/oxygen_sensor_simulator/
Kevin Pierson
