2002 Kia Spectra Questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9924
Printed Date: May 10, 2026 at 4:32 AM
Topic: 2002 Kia Spectra Questions
Posted By: undecided5150
Subject: 2002 Kia Spectra Questions
Date Posted: February 22, 2003 at 11:09 PM
Alright guys this is a few part question......
1. I can't get my dash trim completely off because it gets stuck against my steering wheel.  I had a really hard time installing my radio because that car doesn't have a dash kit, and it doesn't exactly iso mount well.  Plus since I couldn't get the trim completely off I had very little room to try sneaking the radio behind the dash trim. So it looks like crap and I'm going to have a really hard time fixing it so I was hoping someone had a trick, besides breaking it, how I can get that trim off.  If I had a tilt steering wheel I don't think I'd be having this problem, but I know it has to be able to come off without having tilt wheel......any suggestions?
2.  I'm going to be installing a remote start and I'm too lazy to meter every last wire to see what does what.  Does anyone have a diagram I can use as a reference point?  I'll meter those wires to be safe, but other than that....I'm just too lazy.
3.  Does anybody have any suggestions or tips on this car just so I know what to look out for?!?
Thanks,
Undecided5150
Posted By: dashrat77
Date Posted: February 23, 2003 at 6:01 AM
|              12V|red or black        |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|WHITE/ blue          |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|green               |+  |ignition harness            |
|       POWER LOCK|add actuator        |   |in driver door              |
|     POWER UNLOCK|same                |   |                            |
| PARKING LIGHTS +|pink/black          |   |DKP in white 18 pin plug    |
| PARKING LIGHTS -|green               |   |headlight switch            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|lt. GREEN/ red       |-  |DKP in white 18 pin plug    |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ YELLOW        |-  |DKP in white 18 pin plug    |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|yellow/white        |   |plug on strut tower         |
|      SPEED SENSE|ORANGE / black        |4  |pin 42 @ ECM *1             |
|       BRAKE WIRE|RED / black           |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ orange        |-  |steering column             |
Notes:
*1 The ECM is located under the center console to the right of the gas pedal.
