How to Test VSS?
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10733
Printed Date: May 06, 2026 at 4:43 PM
Topic: How to Test VSS?
Posted By: 96Bronco
Subject: How to Test VSS?
Date Posted: March 11, 2003 at 9:59 AM
I need to know how i would go about testing to make sure that a particular wire is actually the VSS. Is there any way to do this with a multimeter?
Posted By: NowYaKnow
Date Posted: March 11, 2003 at 9:01 PM
Set your multimeter to read AC volts. Put the gear in car and start to move/drive. It should jump up around a volt or so when you start moving and drop back down when you stop..You should only have to move a couple feet or so. Just try and keep an eye on where your going and not just on the meter!
Date Posted: March 11, 2003 at 9:02 PM
"Put the gear in car and start to move/drive"
Oops..Put the CAR in GEAR and start to move..Long day..
