2003 Sunfire cruise control
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32814
Printed Date: April 10, 2026 at 7:26 PM
Topic: 2003 Sunfire cruise control
Posted By: opj38
Subject: 2003 Sunfire cruise control
Date Posted: May 26, 2004 at 10:42 PM
hi I am Trying to install a cruise control in a sunfire and would like to know if the Vss wire is also located in the Obd11 test plug located under the dash or do i have to go to the PCM. If it is then which wire or what color is it.
Thanks in advance
Posted By: Velocity Motors
Date Posted: May 27, 2004 at 9:22 AM
VSS Wire: LOCATION 12- BLUE CONNECTOR OF ECM POSITION 34 VSS Wire Color: GREEN / WHITE VSS Pulse: 4000 VSS Tach Wire: LOCATION12- BLACK CONNECTOR OF THE ECM- ONLY WHITE WIRE Tach Signal Wire Color: WHITE Brake Switch Positive: ORANGE Brake Switch Negative: WHITE
------------- Jeff
Posted By: opj38
Date Posted: May 27, 2004 at 9:40 AM
Thank you for the quick response, but one little question, Where is the ECM located in this car , inside or in the engine compartment?
Date Posted: May 27, 2004 at 10:01 AM
The PCM is on the passenger side rear of the engine compartment
------------- Jeff
Posted By: opj38
Date Posted: May 27, 2004 at 8:45 PM
one more. this is a electric servo , big and in the passenger side there is not enough room , so this is where to mount it . Also the cable is very long, can i mount the servo and cut the cable to length.
Date Posted: May 28, 2004 at 12:14 AM
Yes, you can cut the wire to length if necessary.
------------- Jeff
