Tach Signal 2004 Focus 2.3
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38828
Printed Date: March 22, 2026 at 1:16 PM
Topic: Tach Signal 2004 Focus 2.3
Posted By: a223818
Subject: Tach Signal 2004 Focus 2.3
Date Posted: September 08, 2004 at 8:29 PM
Hi,
I have installed an Audiovox cruise control in my 2004 Ford Focus SE Wagon. Everything is working fine but I cannot figure out how to hookup the tach wire. My car has the 2.3L engine and there are coils for each sparkplug mounted directly on the plug.
I have searched this forum and the wiring diagram but see no mention of any tach lead.
Does anyone have any ideas?
Bruce
Posted By: mo12v
Date Posted: September 09, 2004 at 9:06 AM
I have:
Tach SignalBLACK/ ORANGEAT IGNITION COIL
OR
BLACK / GREEN at 3 Pin connector on Dist. Igniter
MO
Posted By: a223818
Date Posted: September 10, 2004 at 10:45 AM
You mean at each ignition coil or just one?
Where is the Dist Igniter located? The car does not have a Distributor.
Bruce
