Audiovox CCS-100 problem
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55533
Printed Date: March 22, 2026 at 1:09 PM
Topic: Audiovox CCS-100 problem
Posted By: fastone
Subject: Audiovox CCS-100 problem
Date Posted: May 11, 2005 at 10:44 AM
I installed the CCS-100 on my 04 Nissan Frontier 2.4L and it worked fine. I was still in the "prototype mode", you know, wires hanging everywhere and parts all over the truck. I put everything back together and permanently connected all the wiring and now when I engage the cruise it pulls the throttle for just a second and disengages immediately. You have to turn the key off and back on before it will even attempt to engage again. I didn't change any wiring, just made permanent connections on the main power and ground. Any ideas?
------------- Famous last words: Hey man, what's this wire do?
Posted By: fastone
Date Posted: May 12, 2005 at 1:44 PM
Ok, well just in case anybody's wondering, it started working again the next evening and has been working fine every since. Hmmm. Bad connection, brain fart, I dunno.
