Frigette on 05 silverado
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60942
Printed Date: March 22, 2026 at 9:47 AM
Topic: Frigette on 05 silverado
Posted By: Rondh
Subject: Frigette on 05 silverado
Date Posted: August 08, 2005 at 2:13 PM
I bought a Frigette brand cruise control for a 2005 Silverado 4.3L V6. I all so have
the GM handle with the four pin connector. There was no instructions or wiring diagram
with it. Wondering how to connect it up. Wire color on handle is Blue, Black,Pink,
and Gray.
The following is the wiring on the 10 pin OEM cruise plug near the brake booster.
A. Gray F. Brown
B. Dark Blue G. Light Blue
C. Gray/Brown H. Empty
D. BROWN / White J. Blue/Brown
E. BLACK/ White K. GREEN / WHITE
Want to know where the four wires from handle connects to the 10 pin OEM.
Or the signals of the 10 pin connector, for instants pin K is Vss.
Posted By: mo12v
Date Posted: August 08, 2005 at 7:48 PM
check your P M
------------- MO
