2001 Dodge Dakota V6 5speed
Forum Name: Cruise Controls
Forum Discription: Cruise Control Settings, Tach Signal, VSS PPM(Vehicle Speed Signal Pulses Per Mile), Vacuum, Brake, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65595
Printed Date: February 12, 2026 at 4:13 AM
Topic: 2001 Dodge Dakota V6 5speed
Posted By: drshm
Subject: 2001 Dodge Dakota V6 5speed
Date Posted: November 04, 2005 at 10:55 AM
I am installing a cruise control for my truck. I have never done one before. I have done several remote car starter/keyless entry systems before and car audio. I am looking for a wireing diagram for my truck for the connections i need for cruise control.. ie break pettal, VSS, i can get a list if needed:-)
Posted By: KarTuneMan
Date Posted: November 04, 2005 at 12:37 PM
Check the search button at the top right of the page...if its NOT there just hang on....someone here willl have your answerposted_image
Posted By: drshm
Date Posted: November 04, 2005 at 1:01 PM
Thanks.. I did search before i asked though! :-)
Posted By: mo12v
Date Posted: November 04, 2005 at 4:03 PM
Don't know what kind of Cruise you are installing ( hope it's ROSTRA or Audiovox )
Try:
https://www.rostra.com/cruise-control.htm
2001 Dakota
VSS Wire: LOCATION 11- WHITE 32 PIN CONNECTOR OF PCM POSITION B27
VSS Wire Color: WHITE/ ORANGE
VSS Pulse: 8000
VSS Tach Wire: LOCATION 11- BLACK 32 PIN CONNECTOR OF PCM POSITION A7
Tach Signal Wire Color: BLACK/ GRAY
Brake Switch Positive: PINK/BLUE
Brake Switch Negative: WHITE/ TAN
P.S. You should use a Clutch Kit also
MO
Posted By: drshm
Date Posted: November 06, 2005 at 11:29 AM
Posted By: mo12v
Date Posted: November 06, 2005 at 6:26 PM
PCM..............Passenger side Fender near Firewall Under Hood
MO
Posted By: drshm
Date Posted: November 07, 2005 at 1:49 PM
ok since this is what i am installing
https://www.jcwhitney.com/autoparts/Product/showCustom-0/Pr-p_Product.CATENTRY_ID:2001597/c-10101/Nty-1/p-2001597/Ntx-mode+matchallpartial/N-10101/tf-Browse/s-10101/Ntk-AllTextSearchGroup?Ntt=cruise%20control
The electrical connectinos i will need to make are to the truck are
VSS; Tach; Break Peddle; Clutch; Ground, Power, and Ignition? these are aside from the connectons to the cruise module and so forth. they are just the connections i make to the Car?
I ask this cause the DISTRUCTIONS! posted_image aren't very good!!
Thanks again for all the help!!
Posted By: mo12v
Date Posted: November 07, 2005 at 10:05 PM
Not sure of your Question????
MO
Posted By: drshm
Date Posted: November 08, 2005 at 7:22 AM
oh sorry. Im just verifying the connections that i need to make.  is there anything i am missing from the post above?
Chris
Posted By: mo12v
Date Posted: November 09, 2005 at 8:17 AM
As far as Wiring:
That is it..............VSS;  Tach ( some are not needed );   Break Petal ( Cold side ); Clutch ( switch kit needed ); Ground, Power, and Ignition
Other than Clutch Switch Kit, it is a pretty straight forward install
MO
Posted By: drshm
Date Posted: November 11, 2005 at 10:27 AM
now on the dakota there are 3 ignition wires... does it matter what one i use?
Posted By: mo12v
Date Posted: November 11, 2005 at 11:15 AM
You do not have to tie into Ignition Harness if you do not want........Just hook into Fuse Box
Otherwise BLACK/ ORANGE  @ Ignition Harness
MO
