isobaric setup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111641
Printed Date: May 02, 2026 at 8:55 AM
Topic: isobaric setup
Posted By: siggie30
Subject: isobaric setup
Date Posted: February 16, 2009 at 2:28 PM
Hello,
I have been reading like mad for about 2-3 weeks in here and boy, what a massive amount of info to digest. I would like an opinion on the following setup:
Amp: Kicker zx650.4 (2.05 ohm stable)
Fronts: Kicker 6 1/2" components (not important to discussion).
Subs: (2) 65vt 2 ohm svc (6 1/2") currently setup isobarically in a .63 ft^3 enclosed box (will port on Wednesday).
Concern: My subs are wired with the correct phasing (push/pull), one on each channel, but my concern is since it is a stereo amp will the differing frequencies between the two channels cause problems since I am set up isobarically?
If not then good, if so then should I combine the signals from the stock head unit and split at the amp or ?
I was referred here by a customtacos.com member and am impressed with the enthusiasm of the site.
Posted By: DYohn
Date Posted: February 16, 2009 at 6:11 PM
No problem.  Just send the same signal to both channels of the stereo amp.
Posted By: siggie30
Date Posted: February 16, 2009 at 6:15 PM
