suicide doors 99 tahoe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113009
Printed Date: May 03, 2026 at 3:51 PM
Topic: suicide doors 99 tahoe
Posted By: autoapp
Subject: suicide doors 99 tahoe
Date Posted: April 09, 2009 at 11:27 AM
We changed the rear doors to suicide on a 99 Tahoe. I have a large bundle of wires that go from the cab to the inside of the door. I need some sort of rubber boot to house the wires and keep the elements out of the vehicle. Does anyone have any suggestions on who would fabricate something like this?? Or any ideas on how to fabricate something myself. Any input would be welcome.
Posted By: ca$ino
Date Posted: April 09, 2009 at 1:56 PM
You cold always purchase heat shrink wrapping. All wires would be securely held together and able to be move wherever.
------------- Look twice, think thrice, 1 splice/ 1 slice!
This is a phrase i came up with and something i will now live by.
Posted By: autoapp
Date Posted: April 18, 2009 at 10:29 AM
If i use heat shrink it will seal the wires in but it still wont keep the elements out of the truck cause there are holes in the door sill where the wire penetrates the door and the truck. Mainly the truck cause the door penetration is on the bottom side of the door.
Posted By: ckeeler
Date Posted: April 18, 2009 at 1:37 PM
go to the wrecking yard and start looking for some door boots that are gonna work and that you like.
Posted By: richl68
Date Posted: June 20, 2009 at 3:59 PM
I forgot where i found it one time but do search on google for stainless door boots, they basically are nice braided stainless steel lines that screw into the door from the insides and move with the door i think it would be a nice touch. The hot rod guys usually use them when adding power windows and such into cars that never had boots.
Posted By: d_rock_81
Date Posted: June 21, 2009 at 2:32 AM
i also don't remember where i saw this, but someone out there makes a system that gets rid of the wiring totally. it has connections that make contact when the door is closed only so when you open it up there are no wires, (of course nothing in the door works when its open either!!)
------------- Dustin Rockney
Rockstar Autosports
Posted By: jasonkelly
Date Posted: January 18, 2010 at 2:42 AM
Does your tahoe have barn doors or a tailgate? If you have barn doors you should have the connectors that d_rock_81 is talking about. That is what you should look for, theyre spring loaded metal pins and stay in contact when the door is shut but not when it's open.
