rear view mirror rattle
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113182
Printed Date: May 04, 2026 at 3:15 AM
Topic: rear view mirror rattle
Posted By: spmpdr
Subject: rear view mirror rattle
Date Posted: April 15, 2009 at 10:31 PM
anyone got a trick to stop a rearview mirror from rattling
-A vision without a plan is just a hallucination-
Posted By: i am an idiot
Date Posted: April 15, 2009 at 10:37 PM
About the only thing I have found to work, and it works 100% of the time.  Remove the woofer box.
When you say rattling, are you talking about an audible rattle?   Or are you referring to the vibration.
Posted By: spmpdr
Date Posted: April 15, 2009 at 11:52 PM
lol, I mean the vibration fronm the bass. the mirror itself rattles real bad where it connects to the neck, I was thiking of taking it apart and trying to put some dynamat pieces aournd the ball joint area.
Date Posted: April 16, 2009 at 8:31 PM
If you are having to reposition it from the vibration, you may want to try cutting up a bicycle tube or some other thin rubber material.  Dynamat is going to be a bit thick.  This may stop it from shifting, but there is nothing you can do to stop the vibration.
Posted By: bellsracer
Date Posted: May 07, 2009 at 4:44 PM
Yes there is! iaai if he uses a windhield that is 3" +thick, that could absorb the vibration and prevent the neck from bouncing around!
oh wait...
Practical... practical >.<
