mirrored sub box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116222
Printed Date: May 02, 2026 at 7:22 AM
Topic: mirrored sub box
Posted By: 95tegman
Subject: mirrored sub box
Date Posted: September 09, 2009 at 6:05 PM
I want to put a mirroed sub box in my Integra. I am going to out two jl 10w6v2's in there. I know I need to make it out of MDF first but my question is what kind of material should I use for the mirror?
I was thinking if using a mirrored acyrlic plastic on the inside of the box and then using an acrylic clear plastic as the front of the box and just put a carpeted facade over the front.
Does any one have any ideas about this? Where to buy it? How to cut the mirror?
Thanks in advance for all your help.
Posted By: laynlower
Date Posted: September 09, 2009 at 6:12 PM
that sound good. the front of the box will need to be thick to prevent flex. you can make a smaller window into the box to save on money. try your local sign company
------------- live to scrape
scrape to live
LOWLIFE CUSTOMS
