forming without using fiberglass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117091
Printed Date: April 30, 2026 at 7:32 PM
Topic: forming without using fiberglass?
Posted By: mr.sonic.boom
Subject: forming without using fiberglass?
Date Posted: October 19, 2009 at 5:22 PM
Whats up Audio world...
Does anybody know of something that works well when trying to get a form of something w/o using fiberglass? For example something that can be shaped, holds it's form then can be transferred to the wood to be jig sawed.
Tryed looking in other post to see if something has been posted on it but no luck.
I'm new to Every bit of car audio but tryin to learn. Thanks in advance if someone knows something.
Creative thinkers see more solutions than problems.
Posted By: ckeeler
Date Posted: October 19, 2009 at 6:35 PM
what is it you are trying to do?
Posted By: spmpdr
Date Posted: October 19, 2009 at 9:30 PM
there are types of foam that work great for this, I am not sure exactly what types but i know that poly-styrene is not one of them .I will ask my boss what we use tomorrow and post it here when i get off work
-A vision without a plan is just a hallucination-
Posted By: squires500
Date Posted: October 22, 2009 at 8:57 AM
using an ab expanding foam could work. im not quite sure what your doing so its hard to give any advice. you can get a foam from any fiberglass store costs me around $10 per 250ml which expands 2700% will be cheaper in the states and if you buy larger quantities
