cutting circles
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117408
Printed Date: May 01, 2026 at 1:57 AM
Topic: cutting circles
Posted By: pcana11
Subject: cutting circles
Date Posted: November 01, 2009 at 7:11 PM
Ok, im not really new to making speaker boxes, but im just new to cutting the circles out with a router bit considering i just found out that we have one. What type of bit will i need to use for this and any ideas for a router jig?
Posted By: spmpdr
Date Posted: November 01, 2009 at 7:17 PM
theres a sticky on this site of how to do this,It called making circular rings .you will find all the info you need there
-A vision without a plan is just a hallucination-
Posted By: i am an idiot
Date Posted: November 01, 2009 at 7:33 PM
https://www.routertabledepot.com/cijimo300.html
You can make one of the above using a piece of 1/4 inch plexiglass
Posted By: pcana11
Date Posted: November 01, 2009 at 7:46 PM
hey, spmpdr, i couldnt find that topic, i searched making circular rings and circular rings and came up with nothing
Posted By: spmpdr
Date Posted: November 01, 2009 at 7:54 PM
its in this forum its called how to make circular rings ,sorry I dont know how to load the link for it.Just read the stickied topics and you will see it
Posted By: Melted Fabric
Date Posted: November 02, 2009 at 6:04 PM
Sticky #6
https://www.the12volt.com/installbay/forum_posts.asp~TID~58139~PN~1
Here you go.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
Posted By: pcana11
Date Posted: November 02, 2009 at 7:24 PM
thanks, ive read that post and was going to do that, but our router doesnt have the eye holes to put a threaded rod through. I was thinking about taking a 1/4" board and cutting it the same shape as the base and maybe 16 to 17 inches long from the bit and drilling holes in increments of 1/4 inches
Date Posted: November 02, 2009 at 7:38 PM
If you are going to make a custom guide/template and you project requires accuracy, make sure that template is accurate as well
Posted By: pcana11
Date Posted: November 02, 2009 at 7:48 PM
yea, i was gonna make sure that the inner ring diamater matched up the same on my jig as it does for the sub and outer diamater if i go for flush mount
Date Posted: November 02, 2009 at 7:53 PM
Holes 1/4 inch apart will give you only 1/2 inch intervals.  The thing I posted a link to gives choices in 1/4 inch intervals.  Plexiglass will last much longer than any wood.
Posted By: pcana11
Date Posted: November 10, 2009 at 9:41 PM
well, i dont build boxes much. in the past i have used a jigsaw but i just wasnt pleased with the holes from it. so im breaking the router out and just trying the plywood for my w6 box. speaking of, i will have to post pics for everybody
