plexi glass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12867
Printed Date: May 15, 2026 at 6:14 AM
Topic: plexi glass
Posted By: daslabb
Subject: plexi glass
Date Posted: April 28, 2003 at 3:23 PM
If i was cutting plexi glass with a circular saw what would be the best type blade for that?
Posted By: Velocity Motors
Date Posted: April 29, 2003 at 12:02 AM
One with ALOT of teeth. The more teeth the better and cleaner the cut. Make sure that you place masking tape on the line that you are going to cut to prevent chipping of the plexiglass.
Posted By: chkdsk
Date Posted: April 29, 2003 at 12:14 PM
A sharp blade helps also, and cut nice and slow (smooth).
After you have cut the plexi, sand the cut ends with 220/400 paper then take a small hobby torch and heat the edge up till it goes clear. Makes a very professional edge. Practice on some scrap pieces first till you get the hang of it.
