help with rs750lcd
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12988
Printed Date: May 15, 2026 at 9:46 AM
Topic: help with rs750lcd
Posted By: bangi4
Subject: help with rs750lcd
Date Posted: April 30, 2003 at 4:27 PM
Hello, I want to learn to install alarms, so I bought an autopage rs750 I dont plan on using the starter feature, due to having a manual transmission. Well I dont think autopage wrote the manuals for beginers and Im having trouble deciffering with wires I will not need to use on the alarm brain. I have a 92 Toyota Corolla I need to know which wire to use on the brain for the starter disable. any info would be greatfull. Thank you
Posted By: Bob Zam
Date Posted: May 02, 2003 at 8:39 AM
GENERALLY Speaking. An orange wire is used for starter interrupt. It needs to be wired through a relay. For a beginner, there are diagrams for starter interrupt relays. I am not familiar with the autopage wiring and when units also have the starting capabilities, it is easy to get confused and do something incorrect. My advise is to find a shop that installs your rs750 and stop by and inquire about what you are trying to accomplish.
Posted By: CarTrix
Date Posted: May 15, 2003 at 5:20 PM
Just saw this...I have installed a ton of 750's.....Do you still need help? If so, let me know!!
Erik
