newbie askin for advice
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13903
Printed Date: March 28, 2026 at 5:33 AM
Topic: newbie askin for advice
Posted By: davywavy4186
Subject: newbie askin for advice
Date Posted: May 23, 2003 at 4:22 PM
hey wuts up im kinda new at this stuff and i understand some of the basics but i was wondering i noticed in the tutorial that he makes a mold of the back and then puts in the sub rings and thens fiberglasses the front. wut i was wondering is if u r doing large enough of a setup do u need to do the the back or can u just do the front part and leave that bac open like if its goin to be on the floor or against a seat....?
my other question is once its all done and ready to go in how does it stay in? like how do u seal around or stick it too the inside of the trunk i hope this all makes sense and i hope i can get some replys thanx!!!
Posted By: Velocity Motors
Date Posted: May 23, 2003 at 4:33 PM
If you have nothing in the back for the front piece to wrap around, then you will not be able to remove the enclsoure. You have to have a back piece in order to have an enclosure unless it's an infinite baffle set up. without having the back you have no way of " sticking " the front piece to the back piece.
------------- Jeff
Date Posted: May 27, 2003 at 3:18 PM
wuts up rite now im lookin at puttin 4 rockford fostgate He's powered by 2 2400 wat amps im puttin a sony head unit in thats goin to be powered by a 1200 wat amp and all my inside speakers will be wired off that same amp im puttin 2 caps in the system i was wonderin if u have any suggestions ideas critisim anything i wanna hear it for the amount that im probably goin to blow on this i wanna get some good feedback also any other info on wut u mite think of would be awsome hopefully im putting it in myself and the trunk will all be in fiberglass when im done with it if u think this mite not be a good idea let me hear it thanx for everything
Date Posted: May 27, 2003 at 5:33 PM
hey wuts up i was wondering if im new at this hole fiberglass thing and i have a good idea at wut im doin and about 50/50 for comfortability do u think i will be able to acually pull it off? and if anyone has any ideas for a pontiac sunfire in the trunk let me know its all needed thanx a lot
Posted By: Tcole
Date Posted: May 27, 2003 at 8:35 PM
HUH??
