calculate volume ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18981
Printed Date: May 12, 2026 at 8:09 PM
Topic: calculate volume ?
Posted By: sebass_tek
Subject: calculate volume ?
Date Posted: September 17, 2003 at 10:52 PM
I want to make a fiberglass  subwoofer enclosure, but I need know how can I calculate the exact volume ? Someone told me that I can fill the enclosure with water to know the esact volume. I Gal = 1 foot c. Is it true? Is there any other way to calculate ? Tanks your help will be really appreciate.
Posted By: aggie altima
Date Posted: September 18, 2003 at 2:17 AM
Instead of water, you can use those packaging peanuts to fill it up, then get a box with a predetermined volume and fill that up with the peanuts from the enclosure (the easiest would probably be a cubic foot, or smaller so you can get as close to an exact measurement as possible). So those peanuts do have more than one use, hahaha. Happy filling.
Date Posted: September 20, 2003 at 4:50 PM
tanks  ! :D
Posted By: specialblendj
Date Posted: September 20, 2003 at 10:53 PM
One gallon is not 1 cu. ft.  I was told that 7.5 gallons of water is 1 cu. ft  This seems like a lot, but you should use the above idea with the peanuts to find out.
Posted By: MuscleHead320lb
Date Posted: September 21, 2003 at 12:49 PM
Think about what you just said.  I know for certain a 5 gal bucket is more than 1 cu. ft.
Posted By: the12volt
Date Posted: September 21, 2003 at 1:10 PM
MuscleHead320lb, specialblendj is very close, there are 7.481 gallons in a cubic foot. One gallon is equal to .13368 ft.^3.
posted_image the12volt • Support the12volt.com
