ps2 Enclosure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20204
Printed Date: May 11, 2026 at 8:01 PM
Topic: ps2 Enclosure
Posted By: lil_mikey
Subject: ps2 Enclosure
Date Posted: October 16, 2003 at 5:24 PM
Alright so me and my buddy wanna make a enclosure so that we can put our ps2 in it as well as take it out when were not at shows..
Wood or fiberglass or a sheet metal box be cool? Any designs or ideas would be useful..
1 is going into a 2002 neon lx and the other in a 2000 sunfire.
Thanks alot!
Posted By: acornstu
Date Posted: October 17, 2003 at 8:55 AM
Thanks alot!
just make an angled box under the dash that it slides into with a couple of bolts or finger nuts   that way all you have to do is unplug it and stuff the wires uner the dash   then just unbolt the bracket, that is what i plan to do annyway and i don't see any problem with it if you hide the bolt hole undet the dash
Posted By: hbk00
Date Posted: November 11, 2003 at 6:15 PM
Make a new center council and make an enclosure there, at least thats what I'm doing. (out of fiberglass) Just remeber not to install your PS2 horizontally, it scratches your laser eye and all your discs get little knicks every time you turn it off. Listen closley when you do turn it off if it happens to be on its side you'll hear a slight little "tic tic tic" noise thats the disc slowing down by knicking your laser lense. Just some FYI I thought you'd like to know if you allready didn't. I've worked on small electronics for 5yrs and PS2s always happen to be the same thing, the laser eye went bad
go custom or go home!!
