will someone explain wet sanding
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25413
Printed Date: May 14, 2026 at 10:45 PM
Topic: will someone explain wet sanding
Posted By: usafsurfer
Subject: will someone explain wet sanding
Date Posted: January 28, 2004 at 4:55 AM
ive read alot about fiberglassing and finishing it and im about to glass my doors and put 3 componet set in them but when it comes to finishing it i dont under stand the wetsanding ive read about
thanks
Posted By: pureRF
Date Posted: January 28, 2004 at 3:39 PM
wetsanding is just like regular sanding but with water. Wetsandpaper can get wet and still be used to sand and this gives it the ability to make a smoother finish. Go to walmart or anywhere and you can find the wetsandpaper.
dream it, build it, fiberglass it
Posted By: Custom_Jim
Date Posted: January 28, 2004 at 3:46 PM
Wet sanding is normally done with the finer grits. Dry sanding is usually for the coarser grits. The water (or oil when doing different steel work) helps to keep from clogging the paper and helps flush away the sanded off material. If you have a rough surface do not just jump in with the finest grit to sand it down but work your way from the coarse grit to the finer grits. If you are doing large flat panels use a block to back up the paper so it will keep the paper from flexing and help flatten the surface. You sometimes have to be imaginative and if you need a longer block, take a paint stick or a piece of straight thin wood or steel and wrap the paper around it and it will get the panel flatter and quicker than with a small block. I have also found out that adding a few drops of dish washing liquid in a gallon of water helps to keep the paper from clogging. Use only water for wet sanding unless it is a steel or stainless part.
Jim/Saint Louis
1968 Chevy II Nova Garage Find 2012
1973 Nova Custom
1974 Spirit of America Nova
1973 Nova Pro-Street
