need custom work PT Cruiser
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26192
Printed Date: May 14, 2026 at 12:30 PM
Topic: need custom work PT Cruiser
Posted By: FredA1974
Subject: need custom work PT Cruiser
Date Posted: February 09, 2004 at 11:29 PM
I am looking for someone that can do work with Fiberglass in the NJ area. What I would like to do is redesign where the factory 5x7's go. I want to have a custome fiberglass set up made to match the inside that houses 2   8" subs (1 on each side). I personaly don't like the way 5x7 sound and don't want to take up trunk space. I was going to go with  JL  AUDIO thinking of the 8w0 because of the small magnet on them. I don't need much power just good sounds. If this is not possible no biggie, I will stick with the 5x7's. If so I was wondering an around about price to have this done. Thanks for all your help and you can e-mail me at SwtNLwPT@msn.com
Date Posted: February 16, 2004 at 3:35 PM
I have got no respose from my post. Maybe it is because there aren't anybody in the Jersey area that does this kinda work. If anybody that have a PT or worked on one and can do fiberglass maybe you can help. Thanks
Posted By: pureRF
Date Posted: February 16, 2004 at 6:27 PM
post a new topic with specific ?s and im sure u will get enough good ideas that you could do the project yourself.
dream it, build it, fiberglass it
Date Posted: February 16, 2004 at 9:19 PM
I don't have time or the time to learn how to work with fiberglass. But what I would like done is.......
I want to have the plastic housing that covers the 5x7's. I want it to be cable to mount and look almost like factory but with an 8" woofer mounting on it. I don't know if it is possible. I think there is enough room to bring it out but not sure. If anyone has a PT and can do fiberglass check it out.
Thanks for the advise and I hope this is a little better
Posted By: S.I.Autosports
Date Posted: February 17, 2004 at 4:56 AM
You may have to stop by a local shop and get their opinion and estimate.
