how much do you charge for FG setups
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27681
Printed Date: May 13, 2026 at 2:19 AM
Topic: how much do you charge for FG setups
Posted By: 4play
Subject: how much do you charge for FG setups
Date Posted: March 03, 2004 at 8:54 PM
how much do u guy's usually charge for FG setups. For example, speaker pods. And how much for bigger work, for example custum trunk... Do you guy's charge per hour or by difficulty of the setup.... Thankx in advance
Posted By: soup
Date Posted: March 03, 2004 at 8:56 PM
I have been wondering this myself, what type of formula do youy usually use to determine how much a project is worth?
Posted By: auex
Date Posted: March 03, 2004 at 9:09 PM
It really depends. For some basic kick's for mid's and tweets would be around $250. A full custom fiberglass trunk could easily go into the thousands in labor alone. Hell, the half assed box I have in my trunk would go for over $800 in labor alone.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: 93accordSE
Date Posted: March 03, 2004 at 9:17 PM
I would charge the person supply costs for the project plus labor costs per hour. I am not a professional, but hope to be one day... -------------
Posted By: ISMOKEALONE
Date Posted: March 03, 2004 at 9:30 PM
as much as i could possibly get
Posted By: audiomechanic
Date Posted: March 03, 2004 at 10:09 PM
after a while you will know an approximate time it will take to complete. you will also know what you like to use as far as materials.
you need to figure out exactly( down to how it will mount, and what screws you will use) to give an accurate quote. the more details you think of before hand, the less surprises you will have when you are doing it. also you want to have a good idea of the amount of sand paper and other disposable supplies you will use on the project. disposable supplies, mistakes, and not planning, are the most common reasons for loss of profit.
the general rate for custom work is between 45 and 100 per hour, depending on your reputation and knowledge.
Posted By: sam1
Date Posted: March 04, 2004 at 10:03 AM
i learned how to fiberglass thru this board and another tutorial site. its easy and itll save you alot of money to do it yourself. my two boxes wont cost more than 150 by the time im done. plus, once you know how to do it, the possiblities are endless as long as you have an imagination.
Posted By: 4play
Date Posted: March 04, 2004 at 9:19 PM
wicked guy's ....... totally forgot about shop supplies .... thanx
