Molding Fiberglass to Vinyl
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30000
Printed Date: May 12, 2026 at 2:50 AM
Topic: Molding Fiberglass to Vinyl
Posted By: Voodoosoup
Subject: Molding Fiberglass to Vinyl
Date Posted: April 08, 2004 at 6:15 PM
hey everybody,
I made a fiberglass insert for my center console lid that I'm installing a USB trackpad into. I nee to know what product I need to buy in order to mold the fiberglass insert to the padded vinyl console lid. I want to have a smooth transition between the fiberglass insert and the lid. I will be re-tuxturing and painting it I'm done molding it.
Also what kind of paint would I need that would work with both the vinyl and the fiberglass part.
Thanks,
Voodoosoup
Posted By: audiomechanic
Date Posted: April 18, 2004 at 8:10 PM
this maybe too late ......but that is hard to do. you might want to try the 3m plastic repair for flexable plactic. there should be a filler and one to smooth it out. then use regular primer with as much flex additive as it recommended. then add it to your paint and clear too. that is the only way i can think of to do it. let the primer sit for a day or so to fully adhere. and you might want to spray it with a adhesion promoter too.
