Air Bubbles
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31905
Printed Date: May 13, 2026 at 3:34 AM
Topic: Air Bubbles
Posted By: Spaceman Spiff
Subject: Air Bubbles
Date Posted: May 10, 2004 at 9:12 AM
So, How big a problem are air bubbles really? I made my mold this weekend but no matter how hard I tried I just couldn't get rid of all the bubbles. The more I tried to make it better, the more the mold suffered. This enclosure is going to house a single 10 @ 320rms and I'm sure that will play a part in structure integrity. Will I be safer if I make it thicker or am I just being overly concerned about something that isn't quite as big a deal as it is made out to be?
Posted By: 93accordSE
Date Posted: May 10, 2004 at 9:18 AM
If they are small bubbles then it should hurt the structure too much. They will only weaken it. When you sand it down make sure you fill them with body filler.
Date Posted: May 10, 2004 at 9:22 AM
Well, they are on the inside of the enclosure, the initial mold piece. Anything that was large enough I dremelled and re-filled. When the work "weak" is used, does this mean that subwoofer energy is going to be lost through the walls, or that there is potential for the enclosure to crack? Both are bad but the enclosure cracking would obviously be worse.
Date Posted: May 10, 2004 at 9:27 AM
Aslong as you refilled the big ones, it should be fine. Make sure that the peice cannot "flex" when being pressed on. Otherwise it will be able to crack.
