Wet sand?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33512
Printed Date: May 15, 2026 at 1:52 AM
Topic: Wet sand?
Posted By: hersheyloc
Subject: Wet sand?
Date Posted: June 08, 2004 at 12:09 PM
Hey, Im having some problems with my wetsanding. The primer keeps getting all stuck in the paper, and starts getting all flakey and peely. Is there sumthing I've forgotten to do? Help please! I need to get this done today. Thanx
Posted By: pureRF
Date Posted: June 08, 2004 at 1:05 PM
Ive never had that problem but a few things it could be is your using the wrong kind of primer or your primer isnt fully dry. The primer i use shows a car on the front of the can and says wetsandable. Your primer may not be wetsandable. Also, make sure your primer is totally dry. shouldnt be hard since its summer.
dream it, build it, fiberglass it
Posted By: audiomechanic
Date Posted: June 08, 2004 at 7:47 PM
what are you priming?
what grit are you sanding to before you prime?
what kind( brand/model #) of primer are you using?
what grit are you sanding with?
Posted By: drunkenbreaker
Date Posted: June 09, 2004 at 10:59 PM
consider some adhesion promoter. It sounds like the primer is adhering. If it's aerasol primer i don't know if it's brand specific, but if it's automotive paint I'm sure the same company that makes the primer also makes an adhesion promoter.
Posted By: mikedawg
Date Posted: June 15, 2004 at 2:58 AM
it sounds like youre using a spray can. dont wet sand. just sand it all off and buy an automotive primer.
------------- always looking for new info and willing to give it
