fiberglass door panels
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33684
Printed Date: May 15, 2026 at 12:30 PM
Topic: fiberglass door panels
Posted By: satfrk32
Subject: fiberglass door panels
Date Posted: June 11, 2004 at 12:26 PM
im in the process of putting tons of mods on my car. one thing i would like to do is plan out how im gonna totally redesign my interior including the door panels. most of the door panels are vinyl, but one small section is this very hard cloth. im thinking bout just wrapping the area tightly with a t-shirt by stapling or something around the edges of the cloth. then do the resin/fiberglassing etc, then cover the edges (where the staples are) with small plastic tubing.
question is...can i actually do this? and if i do, will the fiberglass stand with the constant shutting of the doors?
any help appreciated.
Posted By: satfrk32
Date Posted: June 11, 2004 at 12:29 PM
"can i actually do this?" - meaning will the resin stick to the stock cloth on my door panel and to the fiberglass. posted_image.
Posted By: xtreamcc
Date Posted: June 11, 2004 at 9:49 PM
yeah, I think it would work. I've never done a door panel like that before but the theory sounds good to me. I guess it would also depend on how thick the stock cloth is, you might try resining the stock cloth first just to get a hard surface or even drill some small flat head screws into the cloth (fiberglass and metal bond really well) and use them to support the actual cloth when attempting to bond the pieces. Well, thats my say, good luck.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
Posted By: drunkenbreaker
Date Posted: June 12, 2004 at 2:00 AM
good post extreamcc, As long as you get a real good sheet of fiberglass cloth on top with zero air bubbles I should work great.  They make rollers just for getting air bubbles out of fiberglass.  They sell them on shopmaninc.com
Posted By: satfrk32
Date Posted: June 12, 2004 at 7:10 PM
thx for the replies xtremcc & drunkbreaker
much appreciated!
