How strong is bondo ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=36968
Printed Date: May 15, 2026 at 11:32 PM
Topic: How strong is bondo ?
Posted By: vdubmk4
Subject: How strong is bondo ?
Date Posted: August 07, 2004 at 6:31 PM
How is strong is bondo compared to the actual fiberglass and resin combination ? Is it stonger thinner or does it matter ?
Fortune: You will continue to take chances, and be glad you did.
Posted By: Velocity Motors
Date Posted: August 07, 2004 at 6:58 PM
Bondo is not meant to be a reinforcement layer. It's only used  to smooth out finished work. Fiberglass is a much stronger material than bondo is.
Posted By: Alpine Guy
Date Posted: August 07, 2004 at 10:15 PM
if you make a big slab of bondo you can break it very easy, , if you make a big slab of fiberglass it will flex ( if it were flat)  but i wouldn't break, , unless you really tryed.
Posted By: xtreamcc
Date Posted: August 07, 2004 at 11:54 PM
if u use bondo properly u can fill in pretty deep with it, again like was said about it is not for reinforcing, mearly feeling in and smoothing. I do not suggest using it to make any boxes (that mustang wasn't exactly what I'd call a proper use of bondo) but if you use bondo to mold/sculpt the shape on the outside of a box or panel u can use it to about 1/8" thickness before it starts going to crap on you. A good method to use if you have a thicker area u need to build up would be to lay a layer of bondo (fairly thin, bout 1/16-1/8), let it dry and lay a layer of fiberglass over it, then repeat this process till u have the desired height, sand down, and finish. Anyway, bondo is definately not strong by itself unless being used to fill pits or what not.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
Posted By: archemedes
Date Posted: August 08, 2004 at 6:12 PM
bondo's proper name is plastic filler that kinda says what it does
