Circle cutting jig for router
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37281
Printed Date: May 16, 2026 at 2:31 PM
Topic: Circle cutting jig for router
Posted By: Wyboy
Subject: Circle cutting jig for router
Date Posted: August 12, 2004 at 10:57 PM
Hey all, I have a Craftsman plunge router that i just bought and im trying to find a circle cutting jig for it, anyone know where to get one?
Posted By: auex
Date Posted: August 12, 2004 at 11:21 PM
I make mine out of 1/8 plexi, you could try select products and it is called a perfect circle.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: masterwacker
Date Posted: August 13, 2004 at 1:55 AM
There are several generic kits out there.  I have seen several of them at woodworking stores.  I however agree with auex in building one out of plexi.  That is what I did and I made mine adjustable and also it can make ovals too.  I have found if you take the time you can custom build a lot of add ons like this and make them better, cheaper, and more geared to what you are going to use it for than what the manufacturer intended the jig to be used for.  Good luck.
Eat, Sleep, and Off-Road. Everything else is meaningless details.
Posted By: NowYaKnow
Date Posted: August 13, 2004 at 6:07 AM
I use the one made by Jasper Audio which can be bought at parts express. Here's a link:
https://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=365-250
Mike
Posted By: mj239air
Date Posted: August 13, 2004 at 7:18 AM
I have a Craftsman plunge router as well and I just made mine out of 1/4 inch plywood. I use it for a while until it wears out and make another. Very inexpensive, but works the same as anything else. I have only had to make 2 because the first one lasted me forever.
Posted By: rolln_on_em
Date Posted: August 13, 2004 at 12:17 PM
I have both Jasper jigs both work very welland strongly suggest, 1/16 inch hole incramints - very useful
Yeah I drive a slow car; but damn it looks good
Posted By: CarAudioHelp
Date Posted: August 13, 2004 at 3:59 PM
I use and recommend the Jasper jigs. Amazon carries them at the best price. Do a search for "jasper circle jig".
