subs for durango
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39367
Printed Date: May 12, 2026 at 4:10 AM
Topic: subs for durango
Posted By: murphy286
Subject: subs for durango
Date Posted: September 19, 2004 at 3:08 PM
It has been awhile since I have been to this site.  I hope ya'll will forgive me, but I need some help.  I have almost everything I need to install my system in my 2000 dodge durango.  I was wondering is there anyway to install two 10" subs in the durango without losing the cargo area in the rear.  My wife and I are avid divers.  We use almost the whole rear area for our diving equipment.  I really want to get the system in, but I'm at a deadlock.  Could I use two 8" and still receive decent bass.  I'm not looking for a bass system, I'm looking for a great sounding system.  I did the measurements and the required volume for my two 10" FUBR (Power Acoustik) subs may not allow me to do this.  Any help would be greatly appreciated.  Thanks.
Posted By: Alpine Guy
Date Posted: September 19, 2004 at 6:32 PM
You may need to look into very small 10" subs, and they have to perform whell in small enclosures.  Im shure you could fit 1 Adire Brahma 10" and that should be whell enough.
Take some measurements and post them meybe.
Posted By: heavilymedicate
Date Posted: September 19, 2004 at 6:56 PM
Do you need all the seating in your Durango? do you have a third row seat? Have you seen this: https://www.the12volt.com/installbay/forum_posts.asp?tid=39376&get=last
The stealth box aside, you do not need two subs to get very good bottom end.  I have 1 10w3 in my suburban and it is more then adequate.  While we all have a subjective view of how much is enough, no one has every listened to my system and said it needed more bass.  The comments i often get are "balanced" and "smooth".  That one 10 can give a good whack in the chest  and make sh*t in that little cup holder on the dash vibrate all around.   It sounded louder in my wife’s 00' Subaru Legacy, but the cabin in the legacy is about 1/3 the size of the suburban.  If I ever upgraded it would be to a 12", probably a 12w3 v2, alpine type S or Infinity Kappa perfect.  The quality of your subwoofer has allot to do with the output and the quality of bass.
If I was in your situation I would look into getting one 12 and be prepared to feed it near the recommended RMS power rating to milk it for everything you can get.
Ok, there is this:  https://www.cardomain.com/item/MTXDD8T45  Im just not a fan of MTX's low end stuff and I would not personally choose 1 8".
Date Posted: September 19, 2004 at 7:28 PM
Doh!  Linked the wrong page earlier, sorry:  https://www.jlaudio.com/stealthbox/durango.html
Posted By: boxmaker85
Date Posted: September 19, 2004 at 11:26 PM
Is money an ( a major) issue? If not a JL 10W6 hits excellent in a nice small sealed box and placed correctly, with adequate power, will be louder and better sounding than many other subs out there.  Durango's have plenty of room so even .75 cuft would not be a major issue.
Posted By: WILL85IROC
Date Posted: September 21, 2004 at 1:48 PM
i have a 2000 durango r/t and i have 3 jl audio 10's in a box that fit perfectly behing the 3rd row....  i need my space also cuase i have a wife and twins..... and i also travel alot....       its about 450w which is more than enough for me and hits hard.  just tighted your plate and put some rubber behind it....    i can email u the demensions if u want...   the speakers came with the box so i guess jl designed it for suv's
" WILL85IROC "
Posted By: HottAccord
Date Posted: September 21, 2004 at 3:23 PM
I would have to agree with boxmaker here...the JLW6 is a good driver and efficient and will perform well in a small sealed box.
Im a fiberglass whore!!
Date Posted: September 21, 2004 at 3:26 PM
yeah mine hits very hard, i get headaches every day!
" WILL85IROC "
Date Posted: September 21, 2004 at 8:20 PM
Lookin at getting two myself (10w6)  might upgrade to the w7 depends on the financial situation
Date Posted: September 23, 2004 at 11:21 AM
Power Acoustik states it's FUBR 10" only requires .5 cubic ft of vol. for a sealed enclosure.  Could I reduce that if I use Polyfill?  Thanks to all for the input.  As for the 3rd row seat, yes I need it.  I have 4 children.  OUCH!!
Date Posted: September 23, 2004 at 11:24 AM
I'm sorry, I meant to say could I reduce the size of the box even more it I use Polyfill?
Date Posted: September 23, 2004 at 2:35 PM
Yeah, ive got 3 girls and a boy on the way, I need my seats to Murphy.
No, I would not try to make a smaller box by adding poly fill.  It affects the enclosure in a very small way and the .5 quoted is a absolute minimum box size.  Be sure to subtract the displacement of the woofer when you build the box.  So if the woofer displaces .20 cu ft. then you box would have to be .70 cu ft. to meet your min. requirement.
PA is not known for being a great brand name, but you could do worse.  Id bet you were attracted by the low price for the features they give.  High power handling, small box size.  I would bet that .5 is just a selling point, put on there to compete with the big boys.  I have never heard a FUBR (that i recall) but I have heard other PA stuff and it was all a bit overrated.  Then again it was all cheap so I suppose there is value in there somewhere.
Infinity makes a tight small box sub, the Infinity Kappa Perfect VQ, they had some on sound domain for 150 the other day ( .3 cu ft. min!).  When you go smaller your bass suffers, to compensate I would look into a 12".  I use tens in all my vehicles, but they are all ported.
Date Posted: September 23, 2004 at 2:37 PM
You could build the box to its min. size and then add polyfill to make it seem slightly bigger.  But no way would I build the box smaller and add poly.
Date Posted: September 23, 2004 at 7:35 PM
heavilymedicate  You found the kappa perfect vq on sounddomain.com for HOW MUCH???  Don't you mean $250?  The normal Kappa perfect is 150 but the VQ is $250.  Are you  getting  a discount that the rest of us don't get or something?  lol  (hook me up if you do  posted_image  )
Date Posted: September 24, 2004 at 12:10 AM
It was on a "imperfect" 10" and 12" models, I don’t see them anymore.  They had a slight sticker misplacement on the back.  More like a wrinkle in the sticker.  Never the less, nothing that would hinder playback and they all came with a factory warranty.  WooT!
Date Posted: September 24, 2004 at 6:25 AM
Dang man.  I saw that like a month ago.  Didn't think to check it out.  A STICKER???  Oh well.
Date Posted: September 28, 2004 at 7:17 PM
Thanks for the info.  I will definitely use it.
